Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
Thread: E85 MPG's
  1. #41
    Dec 2008
    4
    Quote Originally Posted by BackyardTurbo_FTW View Post
    Ill be posting my latest tables in a lil bit, picked up another .5 MPG on AVG. I also haven't seen it drop while climbing the mountain to my house, which I used to. So it's def helping more and more. Im running quite a bit more part throttle timing then I was before too.
    Have you posted the updates yet? I will be running 93 octane, but I will try the cam changes. I am trying to make a case for myself for the benefits of loosing the TF dual-boost for the extra HP and mileage.
    I also remember you saying that you might post another tune file to the repository soon. Have you had any time to work with that?
    Thank you for all that you have done for this community.
    84 Fiero swapped 3800SC
    09 Cobalt SS
  2. #42
    Dec 2008
    Nevada
    4,452
    BYT when you run the full E setups do you run into pumping issues? i notice over here that i have to ramp in the fuel pump and loads or the fuel system stresses out. Say if i were to put in a Walboro High Flow Race pump would that alone help with the loss of fuel in the lower ranges on max load or does it require more a combo with the modified pump lobe?
  3. #43
    Sep 2006
    Arizona
    600
    Has anyone gained substantial MPGs using 91 or 93 octane with these cam tables?
    Obviously you can't run those timing tables on the 91-93 octane.
  4. #44
    Dec 2008
    Nevada
    4,452
    i picked up about 4 mpg but i have a outrageously ported head. i have seen these pick up from 1-2 city and 3-4 highway but down here highway is 45 lol
  5. #45
    Oct 2008
    Mebane NC
    475
    I know this post is older but I have a question, when you said "All of the Cam and Timing tables match those, meaning all of each are the same as teh 1 posted above" do you mean the warm and cold tables?
    Everyone, thanks for sharing the information...
  6. #46
    Dec 2008
    Nevada
    4,452
    Each cam has 4 tables for main operation. Min/min min/max max/min and max/max iirc they need to be the same. They should be clustered together in the editor.
  7. #47
    Oct 2008
    Mebane NC
    475
    Quote Originally Posted by cobaltssoverbooster View Post
    Thanks, That's what I thought but I wanted to be sure.
  8. #48
    Oct 2008
    Mebane NC
    475
    These are the tables I was referring too.
    Dennis
  9. #49
    Dec 2008
    Nevada
    4,452
    Yea ok so intk base warm and cold = same/same
    And the Exh base warm and cold = same/same also
    Some people change catalyst heating but once the car is warmed up which isn't long after startup it uses the base warm/cold tables
  10. #50
    Oct 2008
    Mebane NC
    475
    cobaltssoverbooster, thanks
  11. #51
    Tuner in Training 08VRSS's Avatar
    Dec 2012
    Houston TX
    44
    So the new tables that were mentioned to be good gains never got posted? Even gmtech's cam tables in his thread, the link for the pic is dead. Can anyone help me out? Thx
  12. #52
    May 2018
    Steps to maximize E85 mileage
    Can you tell me what to change to the ignition timing on a Ford Focus 2L DI Flex Fuel engine to maximize mileage on E85? How much should I retard or advance the timing? Should I run lean with E85? I'm not interested in more power. I want to keep the power the same as gasoline, but up the mileage with E85. Thanks so much. Don Siefkes 586-596-4765 Also can e-mail me at [email protected]
    This past weekend I went on a road trip with the Cobalt and my plan was while on the drive, I was going to maximize the mileage! So I played and gained a SUBSTANTIAL amount of MPG's! Im now getting better MPG on the E Blend then I was getting on 93 alone. Given, if I work on similar changes with the pump gas tune I could prolly make that better still. This was till a huge improvement!
    Here's my Cam and Timing Tables:
    See if you gain some MPG's as well!
  13. #53
    Dec 2008
    Nevada
    4,452
    your gas mileage will come from reducing the amount of fuel being used under cruise conditions. typically comes from shifting cams to reduce overlap in cruise and running some advance up.
    its a balance between minimal airflow required to make enough torque to achieve the task. when you find the balance the mpg shoots up.
    you posted in the GM section so you wont be getting any values specific to you from this section of the forum.
  14. #54
    May 2019
    3
    Quote Originally Posted by DrLoch View Post
    I was wondering the same thing. Thanks for asking!
  15. #55
    Feb 2010
    The Desert
    480
    Bringing this back from the dead.
    I decided to give BYT's cam tables another shot with the 7163/E60 setup (GMTech's as well, both extremely similar). I noticed a notable drop in overall fuel mileage with both sets of tables after but I can say without a shadow of a doubt, they offer an incredibly smooth driving experience and add a bit of pep in the mid-range. There's definitely a trade-off, economy vs performance.
    I would highly suggest giving these cam tables a go! Just make sure that all of you supporting tables are dialed in a well.
    09 RY Cobalt SS Coupe - 19K miles - Bolt ons + 7163 ZFR, HP tuned on ethanol
    Sold - 09 SRTC Cobalt SS Sedan
    Totaled - 09 VR Cobalt SS Sedan
    Sold - 09 RY Cobalt SS Sedan
