Hi I'm Just wondering if there is somewhere to look to find out the procedures on going mafless on a 2007 HSV LS2? Just need to be pointed in the right direction. Thank you.
You will need the 2.23 beta so you can load the 2.5bar OS into it, that will give you your ve table for mafless tuning and more.
Give it a go yourself first, if it doesnt work out then pay someone.
Thank you for the reply. I have done that but where do i get a VE table to start with, everything is "0" in there? and also how to i get my afr % err histogram to work??
you can generate a new one with scanned data but hey its quicker and easier if someone gives you a tune to base off then use it to modify, if you send me your email address i can send you a tune file to look at but you will need to modify it to suit your own vehicle of course, as for the scanner setup bit hard to tell without seeing it but ill send you one of mine aswell, also if you havent connected the scanner yet to the car with the 2.5 bar setup loaded into it you probly wont find the matchings pids to use? not 100% sure as its been 3-4yrs since i started with the 2.5bar OS.
thank you very much. i will send you my email.
VE HSV R8, cam, full exhaust, VCM Pod CAI, Custom Dyno Tune.... 411hp.
a 05-06 GTO or 05 Corvette VE table can be used as a quick starting point for them.
Thanking all very much for the information
