So admittedly I didn't touch a car last year in any way other than maintenence on my own vehicles. No tuning, grease work, nothing. I am usually pretty heavy with it. I have tuned tons of LSJs with E85, nitrous, methanol, C16, turbo, Harrops, you name it. This year I decided to run my Ion Redline on E85 again. Two years ago I had my old 04 Redline with a Harrop, built motor, ID1000cc injectors, return fuel system, E85, the works. And it ran butter smooth, all the time. This 04 car is different and I feel it is because I slacked last year and maybe forgot some things. All I have done is a 2.8 pulley on the stock blower, intake, full length header and catless full 3" exhaust system, 60s, and it's running E85. NGK BKR7E gapped to .035". The car is super fun on the highway and in cruising gears. But around town it is jerky as hell, has a terrible stumbling idle when I slow down that stalls the car out 50% of the time, other times the idle just bounces bad. When I go to take off after sitting for a minute or two the car bogs like it's going to stall, almost as if it was loaded up with fuel. I have looked over and over the tune. My wideband says all is good, fuel trims aren't crazy off most of the time around town (admitedly on the highway they are, but the car still runs a bit lean). Someone help please! I have attached a long log, the current tune I have gotten to somewhat work, and the config I use. I am just stumped at this point. You can see where the idle surge comes in bad at the very end of the log. And at about frame 10660 is where the car has been sitting at a redlight for a minute and I go to take off. It bucks and stalls out and goes obviously super rich before I can get going.
