Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Tune for 2.2
    May 2011
    17
    Tune for 2.2
    Can someone look at my tune and help me out if you have any questions about the mods please let me know
    Advanced Tuner laser_racer's Avatar
    Jul 2009
    league city tx
    461
    Post all your mods and I will grab my laptop to see what you got going on.
    Advanced Tuner Dr. Nopps's Avatar
    Jan 2011
    I'm proudly a successfull stalker of an honor roll student!
    368
    Thanks for posting your tune. I'm still cherry to all of this stuff and it's amazing for me to finally see the complexity of the newer OS's. (only seen a '97 and an '01 so far) I will not be able to help you as much as the other guys but from the basics I understand it looks like PE mode is disabled in your tune untill 8000RPM. Unless I'm mistaken sometimes you may need the extra fuel it provides, but I'm not that firmiliar with your fuel system. It's tables look very cool. Especially the ability to control injection timing bounaries! Looks to me like your A/C will be disabled. At least when your RPM's are above 0 and untill they drop back down below 0. I know that you may have done this on purpose especially if you've removed the compressor, just pointing it out.
    May 2011
    17
    ok you ready for the list of mods.
    SS SC intake
    Ls4 Big Bore Tb
    60# siemens
    255 walbro
    gt3076r
    weisco 10.1 forged pistons
    eagle rods
    78# springs and retainers
    forged ferrea valve train
    One step colder plugs
    stage three clutch
    umm what else you need for the engine
    Thank you so much for your help the tb scaler needs to be changed to 3775
    May 2011
    17
    no one
    bueller bueller
    Jul 2009
    league city tx
    461
    I sent you a pm
    Jul 2010
    371
    Oh my lord. Your engine still works? You use VE until 7000 rpms, like you basically dont use your maf at all. PE mode doesnt come on right away until 8000 rpms. AND you need to be over 94 or 92 % TPS. You need to set that up to be when boost comes on, and the same with pe mode delay (well that should be even lower). You are commanding WAY WAY too lean for a boosted car in PE mode. I would put your eq ratio to 1.2 or higher. Hell I would go to 1.267 until you have your fuel tuning sorted out. You also still have torque management which right now is the least of your worries. Hell I'm surprised you still have pistons left.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
    May 2011
    17
    thanks for the help this is just a starting tune. something to get started and go from there.
    May 2011
    17
    And i need to put my TPS max at 92-94% and what do you mean ve
    Jul 2010
    371
    Quote Originally Posted by Firefighter404 View Post
    Ve the tables in the speed density section that you have no idea what they mean. When your rpms are below the dynamic airflow rpms it uses those tables which I know you have not tuned cause practically no one knows what the hell to do with those (I dont entirely understand it myself). You want those values to be lower that when you see boost. And you want your TPS values in the PE enable table to be at where you see boost.
    May 2011
    17
    we have done a little bit with those, those are the ones that you scale and then put in a percent and copy to the table right.
    May 2011
    17
    and thanks i know im new and dumb my buddy knows way more then me im tryin to learn
    Jul 2010
    371
    no maf are the ones you scale and use % copy. The VE tables are actually tables of coefficients for variables in 5 dimensional quadratic equations, basically your VE map can only be comprehended as a map by stephen hawkins. There is a way to tune them but its much easier to just force it to only use maf and then hope your maf never fails.
    May 2011
    17
    Quote Originally Posted by Leafy View Post
    lol thanks for the help you got stephens number. hahaha we will change what you said to change this weekend and then i will repost the tune and see what you guys think do you want a log to
    Jul 2009
    league city tx
    461
    Don't break your car heres injector settings for 60s.
    Jul 2009
    league city tx
    461
    Short Pulse Limit is 1.00. Set your dynamic settings to 300 and 200 under airflow tab.
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Quote Originally Posted by laser_racer View Post
    Not sure were you cam up with the injector data, but it is not correct.
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Jul 2009
    league city tx
    461
    Never had any problems with running them. Where would I be able to get more info?
    Sep 2010
    1,303
    From Gregs dvd. it will take some math to make it work with different o.s.'s but it is better then a guess. I have sem 60 injector data for this os and many more. You do have the correct flow rate though.
    Jul 2009
    league city tx
    461
    Quote Originally Posted by Google View Post
    Thank you for dvd info.
