Results 1 to 14 of 14
Thread: Full lean cruise
    Jul 2010
    8
    Full lean cruise
    While driving around town my afr is fine but as soon as I am at aconstant speed my WB reads full lean, I have also seen full rich. This only happens like 100miles after calibrating. I've have tried a few things but to no avail. Is it okay to be full lean at cruise? Any ideas?
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    Not really, how about posting a log and tune.
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Nov 2002
    Central Florida
    2,503
    Do your narrowbands agree that you are dead lean?
    Jul 2010
    8
    I will try and get a log and tune up tomorrow. AS far as my narrow bands I dont believe so. Or at least notthe last time I scanned while this was going on. However I do keep getting a o2 sensor one code like once every 3 months.
    Jul 2010
    8
    alright guys so here is my log and tune. It turns out my NBs are agreeing with the WB. This has been frustrating me for about a year and everyone ive asked about it seems to be stumped. Under WOT the trims 0 out perfectly. But as you can see in the tune at a constant cruise 25-36mph I can lock the NB, WB, and stft at dead rich or dead lean.
    If I calibrate the car, disconnect the battery, or just dont drive the car for about a week it wount do this until a couple days of daily driving.
    Now before you say "hey your IATs and idle are really high" let me explain that this is a 3800 fbody with a Powerdyne, no intercooler, and I moved the idle up to get rid of the clunky sound from the blower.
    And this is a 1995 car with a 97 pcm, it just swapped in. Plug and play.
    To my knowledge all of the NBs are original. I also have the NB right before the cat disconnected and that is where my WB is installed. The post cat NB is also deleted.
    Jul 2010
    8
    No one even has a clue? No suggestions?
    Sep 2010
    1,303
    clearing your trims after a flash?
    Jul 2010
    8
    Yup reset them before scanning
    Jul 2010
    8
    I do believe I will just set the coolant temp to 284 to run the car in open loop all the time. And since I will probably run a little rich while in open loop reduce the PE table some.
    Sep 2010
    1,303
    Looking at your log, I see some strange things. neg timing for one, 02 mv going rich and hanging and lean. I would get the latest beta from support and relog it, and post a new log with a full list of detailed mods.
    Jul 2007
    320
    Quote Originally Posted by Google View Post
    Looking at your log, I see some strange things. neg timing for one......
    Negative timing.... It's a 1997 thing.
    97 Grand Prix GTP (not going to bother listing mods in detail) 1 messed up 97 PCM with about 30-50% of a 2003 calibration and parts of a few others.
    Jul 2010
    8
    I forced the car into PE and open loop at 1500-2500 rpm and now my AFR is nearly perfect.
    May 2011
    Mitchell, Ontario
    10
    i have the same problem on my L67 that i will be posting up a possibility but my O2 sensors drops to 0mv then my car riches up then throws an o2 sensor 1 heater performance fault
    Jul 2010
    8
    See I replaced the o2 that was giving me problems and it changed nothing. But I'm not sure its a problem running 17afr with no load on a cruise if I'm not getting any kr.
