which should I use for my tuning thanks.
2001 Camaro SS A4
You can set the basis individually. If the PID is something
that is used as an index in tuning tables (like MAP, MAF
airflow, Dynamic Cylinder Air, etc.) I try to log it on the
same basis. For "real world" quantities I use English
units because they're just the way I think of things
(MPH, lb-ft, etc.).
If you log the wrong units you can always scale the
column in a .csv file later.
ok so imperial it is, right? LOL
2001 Camaro SS A4
Both units are available. In the Scanner, Preferences>Options & Settings.
Eric - 01 Silverado 5.3 ECSB
ET: [email protected] 1.77 60' 5200 lbs
Crappy website about my truck
My Myspace page
Usually contains explicit material (language, etc..)
It's Peanut Butter Jelly Time!
