I currently have been tuning my 04 gto engine in my Toyota Cressida also with help from a local shop. I love hp tuners. I have a Lexus v8 in my Toyota truck. 1uzfe 4.0 twin cam 32 valve setup. The stock ecu is not really tunable. I already have the crank pulley modified to hold the ls1 24x reluctor wheel with it properly timed as well as the cas hooked up and all the ls1 sensors, coil packs, knock sensors...
I was hoping to be able to tune it all with ls1 throttle body, map sensor, maf, and eventually turbo charge the setup. I know people have told me to just use megasquirt.. but I would rather not.
I know I can just re pin the ecu to change the cylinders that i want to fire but I was curious if there was a way to change it in the pcm itself.
firing order
ls1 - 1-8-7-2-6-5-4-3
1uzfe - 1-8-4-3-6-5-7-2
