Results 1 to 12 of 12
Thread: GTO system readiness failure??
    Mar 2009
    Boise, ID
    81
    Customer came in with on 05 Goat and a tuned ECM. It wont pass emissions here because the sytem readiness tests are showing incomplete for Oxygen sensors, Oxygen sensor heaters, Evaporative system, and catalyst system. There are no codes, and he's driven the thing 100 miles. Did the previous tuner do something that I can reverse to let it test? Thanks.
    Feb 2011
    Boise, Idaho
    16
    Nobody? I thought they had turned these systems off, but they are still working properly, and reporting.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Post the tune. They may not have the DTCs set right for reporting. If they don't report them correctly it will never be ready.
    Plus mileage does not matter if they drive cycle criteria is not met.
    Sulski Performance Tuning
    Mar 2009
    Boise, ID
    81
    Ill have to get the car back in. He didnt want to pay for the license if I couldnt do anything, so I just read it and checked it out. Thanks.
    Jul 2004
    1,579
    "SES Enable" triggers were unchecked I would bet.
    Dec 2009
    So MD
    132
    Where are the Readiness Monitors located in the tune?
    Mar 2009
    Boise, ID
    81
    So, here's the tune file that is currently in the PCM. I havent touched it yet. Thanks to anyone who can see something I cant.
    Has he disconnected the battery in between there or reflashed the tune again?
    9 times outta 10 it has to do with getting the correct drive cycle down to reset all the readiness monitors. I had similar issues on both my 2004 GTO and my 2009 Cobalt SS/TC after tuning. GM has a drive cycle to follow to get them all to reset. Sometimes it won't matter how many miles you drive (I drove a couple hundred and they still wern't "Ready"), you have to hit certain parameters for them to ready. There is a guide online on how to do it, unless you already know.
    Total Masshole.
    2013 F150 FX4 Supercrew Ecoboost - STOCK
    2013 Mustang GT Premium - Lots of Mods, 424 RWHP SOLD
    2009 Cobalt SS/TC Black Sedan
    227whp/224wtq Stock. Dejon CP, K&N SRI, Forge BPV, Catless, BadMab Catless DP, MPx 3" Catback, HPT Tuned 328whp/425wtq. SOLD
    2004 GTO Pulse Red 1 of 512 - R.I.P. 5/31/09
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    Quote Originally Posted by Roger Ramjet View Post
    DTC's affect them as well as items in other tabs such as the General tab for the air pump and EGR. You can verify readiness using the scanner and clicking on the engine icon (in case someone needs that mentioned)
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Jan 2008
    Forney, TX
    982
    Quote Originally Posted by nicstang View Post
    repost in 2.22 and I'll take a look
    Mar 2009
    Boise, ID
    81
    In the General Engine tab, I did notice that the "Catalyst Test" and "Post O2" test are disabled. Should they be on and the reporting be adjusted instead?
    Aug 2006
    5BA8
    3,261
    Shoot me an email [email protected]. I'll only be up for a little while longer.
    EFI specialist
    email=[email protected]
