Results 1 to 2 of 2
Thread: Spark advance vs. octane
    May 2008
    Austin, TX
    60
    I just wanted to verify something with the people here. Does the octane of your gas only give you the ability to increase timing?
    Let's say that your max power was at 22 degrees at WOT on low octane gas and it was not giving any KR. Would getting higher octane change your power potential at all or would it just be a waste to even put in high octane fuel?
    2002 Silverado extended cab 5.3L.
    Volant cold air intake
    Gibson cat-back exhaust
    Electric fan conversion
    2016 Dodge Challenger SXT 3.6L
    Hellcat airbox
    Ported throttlebody
    Pedal Commander
    Mar 2011
    384
    waste unless you increase your timing then you might add a couple horse but probably not much
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
