Im getting full pressure drop on full E85. Running 22* peak timing, .88 PE and the fuel trims are good. I attached a log. Thanks for the help!Attachment 28980
Nvm Termi helped me out!
Glad he's still around.
4 major things for E85. Changing injector constant, injection timing, ramping fuel pressure and finally ramping the PE from .92 to .88 as the pump gets up to speed also helps.
Or buy a set of S1 cams w/injection lobe bump like I did lol..
What was the remedy?
08 SKY Redline
K&N Drop in
Catless DP
GMPP 3Bar MAP sensors
HPTuned
how's that 400whp stock turbo no nitrous going there nick?
Didn't end well as we kept pushing on lol.. Thing was pretty redic on the street tho. You could start a 3rd gear pull then flip it on and the car would instantly burn out at any speed lol. Was good for a laugh but def would advice against it.
HP-Unlimited Tuning and Custom Fabrication
Houston area performance parts dealer
MD800 Mustang Dyno 713-560-3889 Taylor
2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
