Originally Posted by
edcmat-l1
Your A/F is in the high 10s for a bit. Low 11s isn't too bad. I run them all the time in the high 11s on stock bottom ends. Keep your timing conservative, and always, ALWAYS read your plugs. High 11s is not too lean on a stock bottom end. Too rich can be just as bad as too lean.
If you dynoed enough of them, you'd see a trend in how 'happy' these motors are at a certain A/F, and how unhappy they get when you start running them overly rich. As in real low 11s, and high 10s. You can actually see it in the shape of the graph.
If you plan on a pulley change, then yes, I'd go ahead and do a 2 bar SD tune.
