Results 1 to 6 of 6
Thread: Removed MAF which IAT sensor do I get?
    2007 Corvette LS2. E38 ECM. I removed the MAF with built in IAT and replaced my MAP sensor with a Cobalt Tmap. The problem is the range on the TMAP is different. I have the numbers, but don't know how to change them. (Is it even possible?). Or do I need to get a different IAT sensor altogether and use that? If so, which one? I'm asking about the IAT numbers, not the MAP numbers, that parts all good.
    One from a 97-00 C5 will work. Get the pigtail as well so you can wire it in nice.
    2001 Z06 - 417 LS3 - LPE CNC LS3 heads - LPE GT-11 cam - ARH 1 7/8" - LPE C6 intake - RPM 3.73 diff - tuned with HP Tuners
    2008 Silverado 5.3 - Dynatech LT headers - Volant Cool Air intake - 280whp/303wtq - tuned with HP Tuners
    www.davenportmotorsports.com
    Is that a threaded in type?
    No, uses a rubber grommet.
    I solved my iat problem. Ended up adjusting the parameters in the software.
    Would the same setup work for a 2008 Silverado?
