What are you guys using to command timing for Spark Hook testing on the dyno? I can't control spark in any versions of the Scanner for HP Tuners for my 2006 Ion Redline. I am assuming no one else can either, as I can find no threads on any forum discussing how anyone commands timing for the P12 ECU LSJ cars.
Perhaps every other LSJ owner can command timing with the HP Tuners scanner and I can't... maybe HP Tuners doesn't support certain VCM Control functions for my specific OS version that is on my ECU? I wouldn't think that would be the problem, therefore I assume all the LSJ owners can't command timing with the VCM Controlls in the Scanner.
So, again, what are you guys using to command timing so you can tune for MBT in most cells of the timing tables? Or do we just have
Ah, I wish I had my LS1 cars back, almost anything could be modified and controlled in real time with the ECU that "God's Motor" used.
