Hey guys, after a long hard battle with the transmission swap to 4L80E on my 07 Silverado. Everything now functions as it should.
But I picked up a few incredibly strange problems. I have attached my a log file and tune.
The issues I'm having are:
1. When revved to 2500+rpm in park or neutral, the speedometer starts jumping around between 5 and 40 mph......
And the doors start locking and unlocking on their own???
2. When revved and let fall back to idle the truck just decides to retard timing out of it for no reason at an idle, and when you put your foot back in it, the timing doesn't advance, in fact it retards the timing even more with more throttle input to like try and sustain idle speed regardless of throttle position until finally you give it enough gas that the ECM decides to randomly give back the timing. This happens regardless of gear.
I'm at a total loss here with this truck, and it all happened as soon as I swapped in the TCM with a van calibration to re-enable the Cruise Control and Tow Haul mode.
The truck's WOT fueling has just gone to crap after this as well. WB sometimes shows 11.3:1 to 12.9:1? And I haven't even touched the MAF tables. Problems start to show up at frame 4754 on the log.
Hopefully you guys can make something of it, because I sure as hell can't.
Thanks,
-Robbie.
