I have uploaded a copy of my Scanner Config file. My issue is that the map sensor reading isn't correct.
I have a 2 bar SD tune on the car, 2 bar 0-5v GM sensor 2000 camaro ss OS.
(91kap is correct for my altitude)
On manifold pressure SAE it reads 91kpa key on car off
on Manifold 2 bar KPA it reads 41kpa key on car off
If I leave both in the table display then my graph reads 61kpa.
I deleted the MAF and the Original Manifold pressure as per the instruction sheet, but I must be over looking something. I am dynoing tomorrow at noon- so I need the fixed ASAP. thanks for any help.
The voltage reading stays the same in both cases, I would like to leave it as the one that reads 91kpa, but it only goes till 105kpa.
