I need to pick up a set of 60lb injectors for a camaro I'm working on, just wanted to see where you guys are getting them , and what deals are out there
thanks
B-
thanks
B-
The #60 injectors I have in my LS3 (Kenne Bell though) are actually a Ford/ Seimens injector.
Not sure if it helps you, and I haven't tried installing them in a stock intake/fuel rail. They appear to be just a bit longer than the LS pieces, but I'd guess that with a little modding to the rail mounts (spacers in the bolt hols) that it couldn't be done.
They can usually be found for around $50 a piece, and I might be able to get you set up with them if needed.
Talk with Jon over at FIC. He's a great guy to deal with. He's a sponsor over on Tech.
[email protected]
http://corvetteinjectors.com/
2002 Z06 corvette. Heads cam. The usual.
Quintin- I have 60# Seimens that I will be selling - they are 60 mm. What length are the ones you are replacing? I also have new 46# Seimens that are 48 mm that I don't need.
Nate - do you want to sell those LS3 injectors?
