hi trying to tune an 05 colbalt it has smaller pully and bigger injectors
car will hit 15# on the dyno then super charger by pass valve comes open at 4800 rpm and drops to 7 lbs
thanks kyle
thanks kyle
97 k2500 ecsb 5.7l/4l80/4x4 0411 pcm,thorley tri-y's,true duals(no cats),msd ign.,zz4 cam, tuned with efi live
Got a log of it? There's few things that will cause it mostly under torque management by the supercharger settings. I know one way to cut it all the way but you need to make sure you don't have a problem first.
Desired tq and desired tq s/s tables aren't set to max torque.
