I replaced my 29.875 +- tires with 32.5 inch tall tires. I put 32.5 into the gear/tire calculator and committed to the changes. The speedo reads 42 when I am doing 40 by GPS. I changed the tire size in the calculator again to try and compensate and I noticed that in the general table, it changes the General VSS pulses per mile, but does not change the VSS output pulses per mile. Is this the reason that my torque converter locks up at an indicated 55 mph, when previously it locked at 50 indicated mph? I checked "Yes" in autoscale transmission tables.
If the VSS output number needs to be changed, why doesn't the calculator automatically change it?
If I do need to change it, should I just subtract the same percentage from 4000 (pulses per mile output) as is the difference between 29-7/8" and 32-1/2" tires?
Thanks.
