I have a problem that is plagueing me.....
My alternator failed on me... was a delco rebuild and high rpm resulted in a wire coming off the rotor. Took it to a shop that rebuilds alts and starters and they rebuild it. I put it in the car and it works fine. HOWEVER.....
When driving normal, it works fine.
At WOT when COLD, it works fine.
At WOT when HOT, I can watch the lights dim and the voltage gage in the car drop down.
I tried to determine if it is a bad wire going from the PCM to the Alt. Spliced in a new wire from the pcm to plug.... same problem.
I also tried to see if it is rpm or WOT related.... When hot, above 4500 rpm, I can see the lights dim and voltage drop. I put the car in 2nd and slowly rolled into it to 6000 rpm to test.
took alt back out and broght to the shop. they replaced rear cover, brushes, regulator, diods..... it is all new now. They got it good and hot and ran up to 10k on their machine. Works perfectly and put out 130 amps. Put back in car and it does the same thing.
Can anyone tell me if there is something in the PCM that would cause it to do this? anything I could data log to look to see what is commanded?
Not sure if this is messing with anything else such as fuel supply or what not since the voltage is dropping. It would appear to be a PCM issue telling the ALT to cut off??? Not sure why it would do that. Kind of like how the AC shuts down at high RPM or WOT......
I am getting tired of pulling this thing out of the car.
One other note is that I have a Racetronix pump and wire harness that is fed directly from the back of the Alt. Shouldn't matter since the alt is directly connected to the battery that is 4' away.
Car is also a M6 to A4 conversion. I swapped complete engine/trans harness. Doubt its a problem, but worth mentioning.
I don't recall if it did this before the atl stopped working.. Never really drove the car at night to notice
Any help is appreciated. thank you!
