I had my car running fine, then I adjusted some VE tables (idle, low RPM single, low RPM double, high RPM) by 1-3% in some values, trying to dial it in, nothing major. Flashed it back to my car, and it runs like garbage. The idle is about 9.5-10.5. Cruising is the same. This lasts for about 20 minutes, then I get a "lean" CEL. WTF, 9.5-10.5 is not lean. If anything I should be getting a "rich" CEL. Anyways, once this comes on, the car idles fine, right around 14.0-15.0. I flashed the original file I had on the vehicle back to it, and this problem still occurs. Please see attached logs. Something is really wrong, and I need some information to help me fix it. I found this issue in another post on a different forum, but there was no solution, the post just stopped.
Please any help!!!!!
