Results 1 to 8 of 8
Thread: lb7 tune
    Jul 2010
    Spring, TX
    15
    lb7 tune
    i am looking for a tune safe for a stock tranny. Mainly looking for better fuel mileage with decent power. My truck does idle quite a bit because i work in construction. Any input would be great and i also ocassionaly tow about 12000 lbs, thanks
    Advanced Tuner ajamesbond007's Avatar
    Dec 2010
    288
    How much extra power do you want?
    Andrew
    2006 Duramax ECSB - Banks Monster Dual Exhaust, Tie Rod Sleeves, Kennedy Twin Deluxe Lift Pumps, Edge Insight CTS with Pryo, EGR Blocker Plate, PVC Reroute, Suncoast Stage 5 trans with 1056 triple disk converter, Cognito Steering Braces, PPE Race Valve, LML driver side exhaust manifold, AFE Boost Tube, Stock Drop-in BatMoWheel, ProFab Performance 3" Downpipe, Other mods along the way, TUNED by ME... Way too much fun
    Jul 2010
    Spring, TX
    15
    Mainly just mileage but I would say between 50-100
    Feb 2009
    1,931
    Do a search for the Mcrat 20/20 tune(google) and timing calculator how to in this section, should accomplish what you are after.
    Jul 2010
    Spring, TX
    15
    is it easy to do, i am very unfimiliar with hp tuners. also do i need a bigger exhaust truck is still all stock
    Feb 2009
    1,931
    Its not to bad. Read the instructions, if you have any questions ask.
    Mar 2011
    10
    Quote Originally Posted by 02ss View Post
    Probably should check out a Duramax forum before you get too far along there.
    Potential Tuner ripmf666's Avatar
    Sep 2011
    From Md but in KcMo for now til we move back.
    5
    Stock airbox will be fine 4" exhaust helps out. But the 5 spd allison is hurting with much more then 80hp make sure you lift on the 4 to 5 shift. Most need to think what they want in the long run a good tune will make a truck so much nicer to drive.
    Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
    EFI Live tuned by IdahoRob,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter.
    Alot Of thanks To George aka BigDipper
    [email protected]
    1979 Camaro Z28,400sbc bowtie block,Je blower piston,Lunati rods and crank,Brodix weldtech ported heads.J&W ultra Glide,J&W 5500 converter,With new mods should run in the mid 7's to low 8's @ 160+ area old setup at 3660lb went [email protected] on dot tires.
