Anyone know what wire the TPS wire is from the PCM on a 2001 Truck? I just got the Zeitronix WB and need to find this wire. Thanks. I can't find any pinouts online anywhere.
Eric - 01 Silverado 5.3 ECSB
ET: [email protected] 1.77 60' 5200 lbs
Crappy website about my truck
My Myspace page
Usually contains explicit material (language, etc..)
It's Peanut Butter Jelly Time!
check my post here
it is in the lounge, gm sevice information and other stuff
here you will find complete service manual for your chevy, including schematics
There is no replacement for displacement?&&sure there is, its called a Blower!
Sweet! That is a thing of beauty. However, before we saw this, we tapped into the dark blue #24 on the red connector (TPS for 99 F-Body, 99-00 Truck) which appears to work, with the exception that according to the WB Software, it's at 10% at idle and doesn't stay with HP Tuners TPS %.
Looking at the 2001 PCM pinout, the red connector doesn't have a dark blue #24. 2001 allegedly uses blue connector #46 gray for the TPS.
This makes no sense to me, especially since my PCM's wires don't match what manual for the 2001, and it also doesn't completely match the 99-00's either.
My Myspace page
is your truck with or without electronic throttle control?
with etc the tps goes the the tac module.
without etc the tps goes straight to pcm.
without
My Myspace page
