I'm pretty disappointed in the way the torque converter behaves in either normal or performance (tow/haul) mode.
I don't care about the NVH issues, especially while towing, of keeping it locked up.
1) locks up very softly, how do I/is it ok to quicken it up?
2) Is it ok to keep the TC locked during shifts both up and down?
3) How do I get DFCO to actually work? I've tried raising the rpm limits for entry, but it seems like the MAP values don't get low enough to set it into DFCO while letting off the throttle down hills (30-35 kpa). Is the IAC throttle follower letting too much air by?
I've only had hp tuners for a couple weeks so I'm making changes slowly, but I've been working on getting the normal shifting much more like I want it to, starting by copying a 1/2 ton 5.3 strategy and changing it.
2001 2500 4wd truck 3.73's lq4
