Hi All,
I have some remaining issues from a pro tune which the tuner can't seem to resolve. I'm attaching two logs.
coldstartACoff: Cold start until 235*F, then fans on until back to 185*. Ignore AFRerror as I used the wrong AFRCommanded PID in this log. Fixed in the drive log.
drive: Driving around trying to log the symptoms. AC off for the first 10 minutes, then AC on the remainder of the drive.
Frame 259, 340, 371 & 421: overshoots idle but recovers on clutch-in quick stops
Frame 2530: clutch-in quick stop idle overshoot in traffic
Frame 4530: Bucking
Frame 5460: Bucking on decel off gas, overshoots idle RPM
Frame 8445: Engine sensor fuse blows
Frame 11085: Bucking on decel off gas
Frame 11229: Severe bucking on light throttle tip-in
Frame 11520: Bucking
Frame 11670: Bucking
The car is a 98 Z28 with a LS3 longblock w/ 24 tooth reluctor, LS3 injectors, 13lb flywheel. Engine sensor fuse regularly blows due to a short we haven't been able to locate. IAT sensor is in the stock location.
Concerns:
- Bucking at off throttle / light throttle transients
- Idle timing tables don't mesh with the main timing tables
- Seems like my fuel economy isn't very good, but I guess that's subjective
- While I didn't try to reproduce it in these logs, turning on the A/C can sometimes make the motor stumble/die not warmed up. It can happen at idle, or if clutching-in preparing to stop; it's more likely to occur during a stop the harder I stop.
I haven't tried the EOIT adjustment because I am not clear how I apply the spreadsheet numbers to my tables. But if it helps, my EVC & IVO are both 1, IPW @ idle is 3.5ms.
I'd appreciate any detailed information I can use to fix the remaining issues without incurring new issues. I tried a highly recommended tuner over a year ago but that didn't turn out as well as I had hoped
Thank you very much for your help.
Jim
