car: 1996 3.8L camaro with a 97pcm, fully built heads/cam
Heres the issue, I've been running off just the VE tables for a year or so now with little/no issues. My KR has been under control maybe getting 0.5* under part throttle every so often...nothing major, and probably something unavoidable.
Now, I want to go back to a MAF based tune. I followed the Russ K guide and retuned my MAF and put a stock VE table back in. My fueling on the wideband looks great...right in at the low 14's at part throttle, and I haven't done WOT yet.
My problem is, I have HUGE amounts of KR with my maf tune even though my fueling and spark is the same as my VE based tune...even if I pull timing I get KR all over the place as high as 7* or more...I subtract timing and it's still going wild, I put the stock spark table in and still no help.
Why am I showing KR only when tuning off the MAF when fueling is ok? but I am not showing it with the VE based tune?...and FYI the VE tune still does show KR when I get it, as I have gotten 2*'s before when I bumped the spark a little higher in some categories.
Heres a copy of the MAF/MAP tune and a scan from each.
aug29kr is a scan with the MAF
aug30backtosd is a scan back with VE tune
SDbeforereversion2 is the VE tune
and the backtomaf is the MAF tune.
Thanks guys.
Attachment 30494
Attachment 30495
Attachment 30496
Attachment 30497
