Need some help swaping a 4L60 into a car that had a 4L80. The car starts out in first and will only shift into second. Is this a common problem?? Can somone modify this file?
it is not wired the same at all plus the 4l80e used two VSS inputs for the computer.why would you go backwards the 4l80e is way stronger.
2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
LS1Tech sig KRAZY K 2000 TA
Im on a mobile right now so i cant look at your tune. but you have to segment swap the whole tranny section just go to the bin repo and download the file that best matches yours with a 4l60e and send both to support they will switch the segments and send it back correct. repin your plug and good to go
2005 yukon Denali turbo,@15#s 4L80E,1978 z28 lq4,1974 corvette ls6. there is no measurment of power without load.
Thanks for your help. The plugs have been set up for the 4L60 but it just doesn't work
sorry had no software take it the fluid is good and no errors when u scan the tranny, the tune looks fine as far as the tranny looks (for a 4l80e).
sorry what the hell am i saying yours is a 4l80 segment you have to swap the file. mixed u up with another one im doing sorry.
i too am having an issue here. what is it that i have to do?
You guys selling cheap 4L80E's then? I would keep the 80 over the 60 any day, if you have a good one for sale let me know I might be interested depending on where it is.
'03 Chev Silverado 5.3L
'04 GMC Sierra 6.0L
'07 Mustang GT/CS 4.6L
'08 Ford F-350 6.4L
