Hello ive just started using HP software....Im tuning a 2003 ford falcon xr6 turbo.....it has 42lb injectors fitted and at idle air fuel ratio is at 11.0 to 1 ive set ive set the injector flow rate to 52lbs on the low setting and set injector flow rate to 42lbs and the high setting....what else do i need to do
Cheers
Mason Lockyer
