I Have and 2006 Gto, I changed the thermostat to a 160, I cant find in editor where to change the on temp of the Fans. In the help tab it shows there should be Fan1 and Fan2 settings which I do not see. Any suggestions?
I think the 2006 GTO should be the same as my 07 vette. Look under System / Fans / Fan Desired %/ vs. ECT. Note that you can't change the temp scale and it starts at 192°. If you want better control lower than that you'll need to upgrade the OS. It will probably interpolate below 192, so with careful choice of the 192 & 196 cells you may get the fan to come on earlier.
-- J.
2007 Z06, Haltech KBII intake, Katech torquer cam, Kooks 1 7/8 headers and Corsa exhaust (with cats)
