Page 8 of 8 FirstFirst ... 45678
Results 141 to 151 of 151
Thread: Idle Tuning How-To & Guide (w/pictures)
  1. #141
    Advanced Tuner Boost's Avatar
    Dec 2006
    Florida, USA
    303
    Thank you so much Frost!!!!
  2. #142
    Apr 2021
    Shakopee, MN
    98
    Would this also apply to a head and cam swap? What changes would be different if any? I put 706 heads on a 6.0 and also added a BTR stage 2 v2 cam.
    I understand that a cam would need less fuel but I'm offsetting that with more compression, right?
    2006 1500hd LQ4, 706 heads, 1 7/8 long-tube headers, BTR stage 2 v2 cam (212/218 @.50, 553/553, 111 lsa)
  3. #143
    OK so maybe someone can help me with this.
    I have a 5.3 retrofitted in a 56 nomad.
    Injectors are DW 18U-01-0042-8 42 LBS injectors.
    It has a comp cams Muther Thumper cam in it. ( NOt my doing )
    I have tuned cams before and never had this much of an issue.
    I cant even get this thing ti fire and idle at all.
    I seem to only be getting 4 cylinders to fire and it is pig rich when trying to run.
    When I open the throttle to 10% or 100% this thing will not even run at all.
    Since I was having an issue I thought ill go back to basics and read any docs I can. What brought me to hear.
    I followed the guide but this thing wont staty running. It fires like on 4 cylinders but no go.
    I have verified all cylinders coils are firing and engine has compression.
    Im lost on this one, even willing to pay for some help here.
    I currently have no MAF installed either so it does not get in the way.
    Attached are the tune and the cranking scan.
  4. #144
    Apr 2016
    331
    Quote Originally Posted by jpliss View Post
    Doesn't look like you have the MAF failed.
  5. #145
    Sep 2021
    Massachusetts
    10
    Perhaps someone could take a look at my logs and offer any advice. I was having starting issues before I went through this process, It helped a ton!! However I still seem to have an issue where the vehicle hunts for rpm when shifting into gear. eventually it settles as long as I don't try to move. Any ideas where I went wrong?
    Build: 2001 S10, forged LQ4 bottom end, 243 heads, TBSS intake, 90mm sniper, 50# injectors, BTR stage 2 cam 227/235, 2800 stall converter with a 4l60
  6. #146
    Dec 2008
    Nevada
    4,452
    Updated the link in Post #113. Google drive updated security policies and the original link broke.
  7. #147
    Tuner Onomoto's Avatar
    Aug 2018
    Ohio
    120
    This is the process for a DBW correct. Lots of great info in this thread. I am soaking it up like a sponge.
    2001 monte carlo swapped l67 on e85
    XP cam
    gen5 m90
    NorthStar throttle body
    speed daddy headers 3inch exhaust
    3.0 pulley
    lq4 maf
    cold air filter behind bumper
    60 lb injectors
  8. #148
    Tuner in Training Paulster2's Avatar
    Nov 2022
    Stafford, VA
    20
    Quote Originally Posted by Onomoto View Post
    I haven't completely read the whole thread, but it appears the original intent of this was for a DBC, not DBW throttle body. At least that's what is posted up front by the OP.
    Working on being HPTuners literate.
    - Paul J.
  9. #149
    Arizona
    483
    Quote Originally Posted by Paulster2 View Post
    DBW mostly, but there is some DBC info
  10. #150
    Aug 2022
    Did you ever figure this out. i am stuck at the same part...
  11. #151
    Jul 2023
    This is EXCITING SH#@! You've got me rubbing my legs like a cricket (still in box MPVI3). Thank you for the detailed how-to.. the absolute best I've ever seen (on a forum).
