Simple question(s). The Powerdex AFX has a single lead (red) and a two wire ground (black) mated to a single "C" connecting tab.
Now, looking through the help files on the editor, it shows the lead (red) should be connected in either of the first four A/D ports. I'll use #1 for simplicity. However, what do I do with the two wires for ground? Should I split them and use ports #5 AND #6 to connect both wires independently or splice them together and connect them into just ONE of the ground ports?
Thanks.
So, to summarize, all I have to do is to connect just those two wires (well, three if you count the two grounds) and setup the PID?
A.
