Results 1 to 15 of 15
Thread: "Hanging" Idle - Stock 08 Manual Cobalt
    Sep 2008
    Portersville, Pa
    289
    I tried searching on this but wasn't able to find anything other than this problem exists on the factory 08 manual trans Cobalt's. This is an unmodified tune, the customer is complaining of the idle "hanging", took it for a test ride and it does in fact "hang" at higher rpm between shifts. It's a minor annoyance but he would like to have it corrected.
    I tried modifying the Throttle Follower, Idle Coastdown Spark as well as the Clutch Fuel Cutoff enable temp but no dice.
    Any suggestions?
    Thanks in advance!
    i had this problem with an 07 as well, havent figured it out yet. In for answers.
    Jul 2010
    371
    clutch position switch.
    1994 Mazda Miata turbo, aero, hoosiers Class=SSM
    Take my drop box referral and we both get an extra 250 Mb free!
    Sep 2008
    Portersville, Pa
    289
    Quote Originally Posted by Leafy View Post
    Can you elaborate? Is the switch faulty or need to be adjusted?
    Jul 2010
    371
    needs to be replaced. My friends car was suffering the same thing and that was the cause. It eventually threw a cel.
    Advanced Tuner imphat0260's Avatar
    Jan 2006
    STL
    537
    Don't throw parts.... Log the PID/Status bit.... That will tell you right away if the clutch pos switch is fine...
    P&P Tuning
    X2 on the clutch position switch
    Jul 2010
    371
    When its a fsb, I wouldnt consider it throwing parts. I'm not sure its an fsb for the cobalt but it is for the trucks. And knowing GM they likely use the same sensor.
    Jan 2006
    STL
    537
    FSB?? Also, it is throwing parts if its not properly diagnosed and confirmed.... Using the scanner to confirm its bad would not be throwing parts.....
    P&P Tuning
    Jul 2010
    371
    fsb=factory service bulletin.
    Jan 2006
    STL
    537
    Never heard of an FSB..... Been a Double Master ASE tech with dealer for 15 years.... TSB (Technical Service Bulletin) is what the manufacturers refer to them as.... Regardless, you are referring to throwing parts... Matter of fact, there is a bulletin about FIX IT RIGHT THE FIRST TIME..... That means properly diagnosing (which seems to be a hard thing now a days ), not just guessing until you find a part that works...
    P&P Tuning
    Sep 2008
    Portersville, Pa
    289
    Thanks for the info folks (and the entertainment!). I do not have the customers car on site. What is the PID for the clutch switch? The commanded and actual TPS goes to zero when you lift to shift.
    anyone figure this out?
    Sep 2011
    3
    Forgive my ignorance but have you cleaned your throttle body plate? Had this problem on another car and that fixed it.
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    I just did a little thread cleanup...I just deleted a bunch of garbage and bickering that has no place on this forum
    Keep it clean...or as my parents would say..
    imphat0260...
    Leafy....
    Dont make me have to reach back there and separate you two while I'm driving
    -Scott -
