4L80e, 2900 stall, 02 LQ4 short block, LS3 heads/intake/injectors, Patriot extreme springs, EPS .596/.600 222/230 112+4, Edelbrock 90mm TB, 85mm maf, Walbro 255
I set my file up using this:
http://www.hptuners.com/forum/showthread.php?t=36318
Followed the writeup for 5 deg overlap. Car idles up to warm, stalls anytime in gear. Need to get the car to run so I can start VE tuning so I figured I'd do a Russ K to start. I set the IAC counts to 80 when warm last night. When I got home today and went over and did Russ K from a cold start. I noticed tonight while logging in park that the scanner thinks I'm in gear. I also noticed my LTIT for in gear moving. So I finished that up, copied the histogram into my tune into the my raf and figured I'd put it in both just to see if it would idle. Not so much haha. So I guess my questions are if I'm supposed to see Park/Neutral when in park(stupid question I know but I have to ask) and what from the 4L80e tells me I'm in park vs gear. My Reverse lights work on the car, not sure if that means anything. Also, if I set my IAC to 80 last night, why was it in the 120's today? I'm looking for some direction please and any help is appreciated!
