2006 GTO with twin turbo (E40 ECM)
LS2 block, LSA heads, LS9 cam, 9.5:1 compression
FIC 95# injectors
Returnless fuel system @constant 58 PSI
2.5 BAR OS
MAF DISABLED
Wideband installed
Injector parameters received from FIC (IFR, Min PW, short pulse adder, offset, etc)
I made a 50% scaled tune for this setup and it only barely runs. When I crank it, it's very rich and I have to push the pedal to the floor to get it to start (flood mode). I can keep it idling by feathering the accelerator and eventually LTFT kicks in at -20% and it will idle. As soon as I try to give it any throttle, it goes very lean and sputters...sometimes...other times it goes very rich, and still sputters. At these times, LTFT is zero as it has never had the opportunity to learn. It seems like the more I attempt to fix it, the worse it gets.
I finally gave up, took my original 60# injector tune and adjusted the Stoich AFR only. The injector parameters in this tune are from the SD 60's, not the FIC 95's. Yet, this tune starts up immediately, idles smooth and runs without sputtering in all throttle positions. I know this isn't the preferred method of tuning for large injectors, but it runs good on the first attempt.
Does anyone have a 50% scaled E40 tune for FIC 95's they would care to post to the repository that I could use as a template?
