Getting ready to install a cam in my '08 vette, and would like to be able to tune the Virtual VE tables. Can someone confirm if my basic understanding of the tuning process is correct using Bluecat's VE program?
1.) Copy VE equations from my tune into the software to build a VE table
2.) Force MAF off in the tune
3.) Force open loop
4.) Scan AFR % error (commanded vs. actual -Wideband) in histogram (VeLoAltd table) where MAP is column headers and RPM area row headers.
5.) Adjust virtual VE table in the program by the error % observed in the histogram, save table.
6.) Load VE equations into tune from software
Assuming the steps I have outlined are correct, could I also use fuel trims in closed loop to tune the VE table in step 4?. I have 10% ethanol fuel in my area so when I tune the lower rpm/MAF ranges in open loop the wideband the trims are always correcting. If I changed stoich to 14.2 would open loop with the wideband be the preferred option? I've heard the o2's are pretty accurate in idle and part throttle.
Thanks.
