Can we access the E85 timing and fuel tables on the 2010 Camaro?
I was going to use a EFIL COS so I could use the E85 tables to retard timing and adjust fueling when running nitrous. I installed a pin into the ECM that when grounded tells the ECM I am running E85.
Can this be used with HPT also?
I hate having to reflash the ECM every time I want to run nitrous and I do not want to have to buy a LNC or other timing box.
