I bought the license for SD but will not use it anymore, how can I go back to the MAF OS? I tried to flash my ECU with a MAF OS file and it wont work.
Why won't flashing your maf os file work? Are you getting an error of some sort? What year/make/model vehicle? Basic information goes a LONG way.
A tuner also told me that if you go SD OS you cant go back, is this true?
If you're using an E38, you don't have to revert the OS. You just have to change the settings to make it run MAF again. This means not failing it at 0Hz.
http://www.dsxtuning.com
Just say no to bull s***.
Sounds like he's trying to go back to the stock operating system & NOT using write entire.
Anytime you try to change operating systems you MUST use write entire to do so.
