Page 1 of 3 123 LastLast
Results 1 to 20 of 60
Thread: E40 ECM scaling for 160-190lb injectors
    How would I scale the E40 ECM for 160-190lb injectors?
    I currently have my tune scaled 50% which allow up to a 127lb injector.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    like 33%....wow thats alot. Will have little or no resolution down in the driveability area. The actual percentage is 63.5 divided by the rated IFR at 80KpA.
    Ed M
    [email protected]
    I do not even like my tune scaled 50%. 33 would not work. Are their any other ways of going about this?
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by GraphiteSRT View Post
    Not that I am aware of. If I might ask, why such big injectors? Must be a race car where you wouldn't care about driveability......maybe an add-on EFI system in place of the factory system.
    Ed M
    [email protected]
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Divide your IFR by some number, and multiply the stoich AFR by the same number.
    Example... Your injectors flow 80lb. Divide that by two, and multiply stoich so it says 29.4.
    http://www.dsxtuning.com
    Just say no to bull s***.
    this is what i do , works great, makes it much better for tranny tuning as well
    Owner of Cunningham Motorsports
    06 z06
    2016 camaro
    68 Camaro
    2014 e63 amg
    07 LBZ Duramax
    What do you not like about it? I recently did the 50% scaling on my E40 and it's working rather well IMO. This is a daily driver type of vehicle too, so driveability is very important to me. The only complaint so far is that it doesn't always start on the first crank, sometime I have to crank it again. But I'm sure that's tunable. Once it's started though, I can't tell a difference from the previous non-scaled tune.
    2006 GTO, APS TwinTurbo, Stroked LS3 416ci, LSA heads, LS9 cam, 4L80e
    Not that is affects the driveability of the car but the loss of resolution down low is somewhat bothersome. With it scaled 50% the spark table is now doubled and I get no where near the end of the table.
    I found some 120lb injectors that may just be what I need to avoid fudging the stoich afr
    Nov 2005
    Houston, TX
    3,968
    Jez this is the first I've heard of this (scaling stoich). So all the complicated scaling we've been doing for years is now obsolete? Beauty idea.
    Bill Winters
    Out of the LSx tuning game
    Mar 2008
    St. Louis, MO
    4,860
    The stoich trick doesn't address airflow limits.
    Nov 2005
    Houston, TX
    3,968
    Yea but with an E40 speed density tune that doesn't matter. Still not sure I get it though; So I have 100 #'ers, if I was starting off with a stock tune with 33# injectors I would just triple stoich and thats it?
    Bill Winters
    Nov 2005
    Houston, TX
    3,968
    Of course stoich only goes to 32:1. I guess thats why you use an IFR of half of your injectors and just double stoich.
    Bill Winters
    Advanced Tuner gn2beatu's Avatar
    Sep 2011
    Germantown WI
    414
    Did someone recently post something about the E40 having an issue with the easy way (cut IFR in half and double stoich) or was that another ECM?
    2000 Regal GS ~ 3.25 Pulley ~ Headers ~ 3"ex ~ 1.85 Rockers
    Sold 06 TBSS ~ Front Mount T88 ~ 0-30 in 1.17 ~ 0-60 in 3.0
    Wanted ~ Engine-less 95/Older 4x4 ~ Jeep/S-10/Ranger for TT Project
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by 5_Liter_Eater View Post
    The E40 still hits an airflow limit in SD. At least the blown TBSS I worked on did. No matter what, it would lean out until I scaled it.
    Nov 2005
    Houston, TX
    3,968
    Well shoot. E40 strikes again.
    Bill Winters
    Scaling the entire calibration by 50% instead of the Stoich AFR table has been working great for my setup, even with an E40.
    The only real issue I had was with cold and warm cranking. Setting the "Cranking VE vs MAP vs RPM" to 65 versus 100 helped. I also modified "FA Mult Stage 1 vs Time". Most of the time, it would start on the first crank, but not always. Occasionally it would stumble and die. Other times it would crank and crank and finally catch.
    Then I stumbled upon a trick. I leaned out the Primary VE cell at 400 RPM / 105 kPa, and it starts each and every time now, on the first crank, cold or warm, gas or E85.
    There's no other time this cell even comes close to being referenced except during cranking, so it does not affect normal driving.
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    Nice. The Cranking VE must be scaled whether III/IV to get cranking correct. Sometimes when vehicles have problems throwing the MAF codes at cranking I'll have a scaled MAF value at the first cell in the MAF tables to help with cranking if they just replaced a battery or something that would cause the codes to clear.
    '20 AT4
    '01 Suburban 2500 Dad Wagon
    Mar 2008
    St. Louis, MO
    4,860
    Cranking VE bit me the first time I scaled a tune... I couldn't figure out why it started like hell until I finally realize it. Backed it down the same percent, and all the sudden it was fine. D'oh.
    Feb 2007
    Calgary
    155
    This req' PE x the same stoich factor?
    Mar 2008
    St. Louis, MO
    4,860
    No.
