I'll fix it later.
http://www.dsxtuning.com
Just say no to bull s***.
618/618 motor
906/862 spray
Alright, I'm just going to update the first post when there are updates/changes. The VE one is fixed now, properly interprets a zero value, and allows the axis labels to be changed in the E38 custom OS table.
That would be post #54?
BJK
APS TT 630 rwhp/654 rwtq @ 9 psi
'07 C6, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
Post 1 has both spreadsheets now.
Thanks Dave for your great support, both here and on the corvette forum. Merry Christmas to you and your family.
BJK
Merry Christmas from New Jersey today Dave!
618/618 motor
906/862 spray
hey dave, do you know what would be badass? if we could run the spread sheet backwards. aka, i put in the error from my scan log and it makes a new table based on the new values.. i know your bored and everything at this time of the year.
Merry Christmas!
-Carl
p.s. im sticking with the manual, level 6 tr6060 and level 4 zo6 diff with quaife atb. then the new DSS carbon fiber drive shaft, just praying for an after Christmas special to order and see what kind of halfshaft axels i can afford.
I'll sell you a DSS 3.5" driveshaft with LG aluminum couplers for $1100 shipped. It's basically brand new. I'm changing to the Pfadt driveshaft.
You guys being proactive or are you breaking the driveshafts you have? Should I be worried?
I think Carl is getting a little twitchy.
http://forums.corvetteforum.com/1579505936-post103.html
BJK
ive heard horror stories of those aluminum couplers, apparently DSS carbon fiber one doesnt need any
Price wise is a no brainer DSS Carbon Driveshaft 1300 vs PFadt 2000.
I broke my T-56 do I'm upgrading everything.
Carl, any driveshaft needs couplers. You can run one solid one and one rubber/poly on the other end. The Pfadt one is a ton better in quality. I drove my car with the bad TR6060 and aluminum couplers on both ends. It wasn't that bad.
These are what you.
Prothane Couplers
Pfadt uses their own couplers.
Thanks Dave for sharing these with us. It will save sometime for sure. Any chance of adding gen III maf support?
1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
- 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
