Page 5 of 5 FirstFirst 12345
Results 81 to 100 of 100
Thread: MAF Smoothing Tool for most Gen IVs
  1. #81
    Dec 2006
    7
    Thumbs up MAF Gen III Support
    Gen III support would be great.....that would be a big help....
  2. #82
    Sep 2008
    1,668
    What this does is take your existing curve and fit a 3rd order polynomial to it, forcing an intercept at zero (basicaly assuming that at 0Hz, the airflow is 0 lb/min).
    OK I'll be the dumb guy...why isn't mine forcing the intercept to zero? I'm confused.
  3. #83
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Your intercept is zero... Look at the value for 0Hz.
    http://www.dsxtuning.com
    Just say no to bull s***.
  4. #84
    Sep 2008
    1,668
    I guess what I meant to ask is should I be afraid of the negative values?
  5. #85
    Mar 2008
    St. Louis, MO
    4,859
    Just don't use them. I said earlier this is going to carry some error in the lower frequencies.
  6. #86
    Sep 2008
    1,668
    Fair enough. I think I had a converter (or both) clog on me last night anyways, sitting on the highway with the cruise control on...either that or I had the most uneventful noise free engine failure in the history of the world...it just can't stay running. I'll hopefully fix it tonight and then get back to this.
  7. #87
    This is great. Dave, did you ever do one of these for the Gen III PCM?
  8. #88
    Mar 2008
    St. Louis, MO
    4,859
    Nope. I could probably manage when I get some free time.
  9. #89
    Would you just zero out the negative values?
    2003 Escalade ESV, 408, 2.9 Whipple, Dragonslayer, Compstar I-Beams, Wiseco 20cc, PRC LS3/L92 Heads, 231/242 .617".610" 113, ID850's, ARH 1 7/8 LT's, 4L80e, Circle D Triple Disk 2400, SFI Flexplate, Custom 3" Dual Exhaust, LS3 Harness E38/T42 Controllers, ZR-1 MAP, Chiller System
    SemperFi
  10. #90
    Jan 2015
    565
    is this still available
  11. #91
    Jun 2014
    Boulder, CO
    202
    Quote Originally Posted by reubone View Post
    I'm wondering where to find the spreadsheet...
  12. #92
    Quote Originally Posted by pannetron View Post
    Me as well, thank you
  13. #93
    Tuning Addict
    Jan 2015
    6,787
    Not sure if Dave wants this posted or not - honestly not even sure why anyone would want what the editor already does, but here it is - I've also never really used this, just had it in my spreadsheets... Dave if you want me to take it down, just let me know...
    ~Greg Huggins~
  14. #94
    Ya the smoothing function is similar. I actually already put a spreadsheet together that fits a curve based on any polynomial order you desire. Then spit it back out. Pretty easy
  15. #95
    Mar 2008
    St. Louis, MO
    4,859
    I actually don't know why the attachment is gone.
  16. #96
    Nov 2016
    22
    I am trying to understand the spreadsheet, when I put in my current maf settings and compared to the new curve some areas like @ 3000hz went from 6.487 to 16.38. Won't that make my fueling way off by saying there is a lot more air than before?
    Please explain.
  17. #97
    Aug 2017
    Maumelle, AR
    9
    I just found this myself. Copied in my existing data and my values from 150Hz to 2850Hz are now negative. That can't be right, can it?
  18. #98
    Mar 2008
    St. Louis, MO
    4,859
    It's a math based operation. It isn't meant to be gospel or a perfect fix. It is intended to fill in areas where you don't have data or smooth things out.
  19. #99
    Jun 2014
    Boulder, CO
    202
    I'm happy that I just learned that the editor's smoothing function works nicely on non-linear curves!
  20. #100
    Aug 2018
    4
    this looks to be very interesting
