Thread: ac problems
    Sep 2010
    ac problems
    just got my car to idle good. It had problems when going from park to in gear, the idle would drop and sometimes stall. I changed the timing and now no problem. But when i turn on the ac it dose not work. dose anyone have any ideas.
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    yes, your car is a honda and from what I see in your tune and log file your out of blinker fluid and the henwiegh is to much.
    lol, post more info.
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Google View Post
    LOL!
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    405
    2,326
    Quote Originally Posted by jsmith14 View Post
    There are many things that can effect idle quality. Vacuum leaks comes to mind first of all. A sensor that is sending out a fluctuating signal can do it also. But the cure to many idle problems is simply to clean the throttle chamber and Idle Control Solenoid Valve (ICSV). I have fixed many idle speed problems this way. In fact it is the first thing I do when I have this type of complaint. If it still has the idle problem, the ICSV is simple enough to check. and something on honda could be much be helpful they release some new Honda recalls.
