Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 61
Thread: 05 GTO M6 to A4 help with tune files
  1. #21
    custom os what? See my problem? I have no knowledge of what or where you are talking about.
  2. #22
    Apr 2009
    Georgia
    148
    Thank you dsteck and ed! So I can't change the vin unless I have unlimited credits?
  3. #23
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Right. I can change it for you though. You will have to burn more credits unfortunately.
    http://www.dsxtuning.com
    Just say no to bull s***.
  4. #24
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by tom's2005gto View Post
    Forget the custom OS thing. I was confusing you with another poster.
    Take the file I posted and do a write entire. Then you're done. If you want the info from your previous tune, just copy it over to the file I posted with your VIN.
    Quote Originally Posted by BOTDF View Post
    Cheers mate but i cant open the file. It says index was outside the bounds of the array.
    You need the beta.
  5. #25
    Quote Originally Posted by kjhallex View Post
    Wish you were closer.... I have unlimited credits!
    You need the beta.
    I have beta. Ok, I can write entire, but not sure about copying over the custom info from my tune.
  6. #26
    Aug 2006
    5BA8
    3,187
    I don't think he can change the VIN without the unlimited model year. That's the only hang up.
    I think ya can. Not positive, as I'm mostly unlimited licenses. I just tried it in a truck file (I don't have unlimited trucks) and it looks like I can.
    EFI specialist
    email=[email protected]
  7. #27
    Aug 2006
    5BA8
    3,187
    Give it a try and see what happens. If you can send me the PCM, I can probably clone it for you so you don't have to use any more licenses.
    EFI specialist
  8. #28
    key in, turn key = no crank
  9. #29
    Apr 2009
    Georgia
    148
    Ed, I might have to take you up on that offer where are you located? If I only have to buy two credits for the custom os I wont mind that I just don't want to buy four. I should be done with the swap within the next two weeks if everything goes as planned.
    The only reason the vin needs to match is to keep vats happy correct? If so I could just disable it? I don't mind not having it.
  10. #30
    Apr 2009
    Georgia
    148
    Did it crank before you flashed it? Try disconnecting the battery for a few minutes.
  11. #31
    I didn't flash it.
  12. #32
    Apr 2009
    Georgia
    148
    So what did you change?
  13. #33
    not a thing. I'm ready to pour gas on it and light it.
  14. #34
    Mar 2008
    St. Louis, MO
    4,859
    Curtis Loveday tried changing the vin on his file and it wouldn't let him. HPT told him he needed the model year license. I wonder why you're able to.
  15. #35
    Aug 2006
    5BA8
    3,187
    I dunno. It's not grayed out or anything. I can highlight it and delete it and copy in another one. Only thing I did do was save it, because it was a totally unlicensed file.
    I'll try another one that's licensed, but not of the unlimited license variety. I'll let you know something in a min.
    EFI specialist
  16. #36
    Aug 2006
    5BA8
    3,187
    Yep. Worked for me. changed VIN and saved it, opened it back up and it was the changed VIN.
    BTW, I've got other software I can put in any VIN I want. But this I did with just HPT.
    EFI specialist
  17. #37
    just verified, everything on the new harness is plugged in. Still doesn't crank.
  18. #38
    should I unplug the tcm and try cranking it?
  19. #39
    Aug 2006
    5BA8
    3,187
    Did you flash it with the a4 calbration yet? This is getting confusing talking about two different cars here, and neither one of you is being very descriptive of what you're doing, status, etc. No data logs, nothing. How is anyone supposed to help?
    Are you on the A4 cal? Have you logged it while trying to start? Any codes? Do you have a P/N input? Does it say it's in park?
    If you're still on the M6 cal, what are you doing for a clutch switch input?
    EFI specialist
  20. #40
    honestly... I am lost in hptuners.
    I started the post and it has been somewhat side tracked.
    My car was originally an M6 car. 18 months ago we installed a 4l80e and used a pcs tcm2000 to control the tranny, but never could get the speedo to behave correctly.
    so, we decided to swap the main harness with one from a donor a4 car and utilize a harness adapter from pcm4less and their tcm42 that was programmed for my car including vin.
    I scanned the car, no codes. The clutch switches and vats were disabled long ago.
    I have not flashed the earlier posted stock a4 tune file due to concerns, that may be unfounded? I have a heavily modified 427 with tvs2300, modified injectors, and a speed density tune. If I load a stock tune as mentioned, will my car run? Will it damage the engine?
    Or am I not to load the provided stock tune, but somehow use it along with my tune setting? or? or? or?
