We just put an attitude cam, 1.750 long tube headers and a 3200 stall in my friends 2008 TBSS and I am having some trouble tuning.
I am tuning by maf only with STFT's, SD is disabled along with DFCO and LTFT's. The histo is set up to log STFT bank1 against MAF airflow vs. output frequency, bank 1 and 2 keep going complete opposite of one another so I decided to tune by just bank 1. Will this work ok?
Lets say I am starting at 30% stft, when I mulitiply that cell by.995 it should lower it by .5% right? Well by the time I have knocked a few % out of that cell it will start running at -30%. I started out using the STFT sensor to tune and would highlight the entire histo then do a multiply by% half, that was just making it further off.
Basically it seems WAY more sensitive to adjustments then it should.
Would using LTFT's instead help? Or could there be a problem with an o2 sensor? In the scan the STFT jumps back to zero alot, that's just because I freaked out and reset the fuel trims.
it also has a 160 thermostat.
