This tune is from a short drive while logging data for VE tuning. Tune idles well in P/N and most of the time while driving around. I have two apparent issues when coming to a stop while driving.
1) as exhibited in this file around frame number 3400 the engine died at a stoplight and I do not know why.
2) I have a recurring problem with the same effect that is apparently caused by the computer occasionally reading 2% throttle while the blade is closed. I have tried two different sensors and this is an intermittent problem. Most of the time the sensor reads correctly.
data follows:
This is a LQ4 in a 66 chevelle DBC, 2010 camaro intake, LS3 heads milled 0.025, 4l80e, Fuel pressure is 58psi, 227/232 ~.610lift 112+4 cam, base tune is from a 2006 express van, computer and harness were originally from a 2007 express van. I have Wideband and HPpro. This is a 2 bar OS with the MAF failed so that I could adjust the offset on the MAP sensor. STFT LTFT and DEFCO are turned off.
Injector data is possibly wrong. They were supposed to be LS3 injectors but that was obviously wrong and had me ending up with VEs well over 100 for most of the table and throwing lots of other calculations based on cyl air volumes out of wack. From a search of the part number i thought they were 33s and tried that but VE still looked too high so in this tune file I have them down as 31lb/hr. I will probably be getting changed to 42s so I have a known set in the future but this is not all of my problem.
This is my first attempt with HPtuners and while I have read tons on here and feel mostly comfortable with the system it is likely I am missing several key simple concepts so do not hesitate to ask me if I made what some would consider simple mistakes.
thank you for the help
