Results 1 to 15 of 15
Thread: VCM Suite 1.2.0 Announcement
    Sep 2002
    Chicago, IL
    6,395
    Attention: The update will be sent in .exe format to the e-mail address you used for paypal. It will be aproximately 1MB in size. It may be over. If your mail box is through site like hotmail, the 1MB file may be rejected. If you have an alternate e-mail address please PM me your full name, Paypal e-mail used, and the e-mail you would like for the update to be sent to.
    Please make sure you have enough room in your in box for the new file.
    Files will be distributed without new help files. We will distribute new help files hopefully next weekend. This may be done via a web download.
    I would like to send the 1.2.0 distribution out monday afternoon.
    Here is the 1.2.0 change log as it stands today:
    VCM Suite Info:
    Last known good com port is stored and tried first.
    Com ports through 6 are now scanned for interface.
    Increased VCM Info logged information.
    VCM Info default log save path is nolonger location of vcm info.exe
    VCM Suite Info is now located in both the flash and scanner programs under the Help menu. It is no longer its own utility.
    VCM Flash:
    Get VCM Info is now called Get VCM ID's to avoid confusion.
    Improved Get Cable ID in VCM Flash.
    Read fail issues requiring PCM fuse removal resolved.
    Cable status nolonger shows disconnected when you first startup the program.
    Added VCM Suite Info under the help tab.
    VCM Editor:
    Added support for a few 99 Y-Bodies.
    Corrected PE vs RPM table limits for certain vehicles.
    Corrected PE vs ECT vs MAP limits for certain vehicles.
    Added trans type to Info form.
    VCM Scanner:
    Fixed common overflow error.
    Fixed crash error when chosing record while scanning.
    MAF PID's fixed.
    Added space bar start/stop for scanning
    Thanks for your suggestions and support!
    - Keith
    We got this guy Not Sure, ...
    Advanced Tuner Billf6531's Avatar
    Jan 2004
    Calgary, Alberta, Canada
    605
    Re: VCM Suite 1.0.1 Announcement
    This just gets better and better. Many thanks.
    Best regards,
    Bill
    Silver 2003 C5 roadster, M6, Euro red/amber tails, Z06 Ti mufflers, Z06 2 cat H-pipe, Z06 airbox, and HPTuners s/w - available to any Corvette or other GM vehicle in Calgary, and also for Ford and Dodge products, including Cummins
    Nov 2002
    Central Florida
    2,503
    Having it FTP-able off the Customer Login page would
    probably cut your hassle factor, if that were "live", and
    the email user limits would become a non-issue.
    Quote Originally Posted by jimmyblue
    LOL, it's like your reading our mind
    We'll get there...
    I count sheep in hex...
    Mar 2004
    18
    just wonder if the update has been sent out yet.
    Mar 2004
    1
    Do not think it has......
    Sep 2002
    Chicago, IL
    6,395
    Re: VCM Suite 1.2.0 Announcement
    The updates where just sent via e-mail. They where 1.0 to 1.1 MB in size in .exe format. If you had any problems receiving your update please e-mail me directly.
    Thanks!
    Mar 2004
    11
    Just got mine and installed. Awesome! It reads and writes the ecu just fine. No more invalid cable id errors Thanks a bunch. Interesting though.. it seemed to flip back and forth between normal and high speed mode. No biggie.. it seemed to handle it fine. Just curious... is there any risk of causing corruption, or "wearing out" the ecu from multiple re-flashes? I have a hunch I'm going to write to it many, many times
    Nov 2002
    Central Florida
    2,503
    EEPROMs all have a write cycle endurance limit but
    they tend to be in the 10K+ cycles range, at worst-
    case environmentals. So I wouldn't worry, unless you
    tune / program like an infinite number of monkeys.
    Falling back to low speed comms indicates that your
    serial hardware or the management of its buffer are
    marginal, too tardy to hang with full data rate. This
    is what I was seeing on my 100MHz machine. USB
    serial adapter? You might dig into whether there are
    any optimization settings you can do (like allocating
    more incoming buffer space, higher priority servicing
    of data received, no sharing of interrupts (some
    Windows versions think they're smart enough to
    try), etc. but "Plug and Play", you get the plug where
    they say.
    May 2003
    Santa Clarita, Ca
    962
    Quote Originally Posted by FDLS6
    Either your PC is on the ragged edge of being able to handle all of the read/write data or something is talking on your vehicles VPW bus and interrupting the read/write process.
    Either way the software/hardware is finding ways around those communication errors. That's how its supposed to work.
    As for wearing out the Flash chip by reading and writing to it too many times.... not in your lifetime
    Ken
    Mar 2004
    11
    Thanks guys.. yeah, I thought it may have been a silly question about re-flashing too much, but thought I'd ask I was stuck in the magnetic tape world Well, my pc is a p3 650 with 196megs, straight serial connection. I'm not too worried about the switching back and forth from high to low speed. I could have had a hung process in the background that was taking resources.. If it continues to happen, i'll take a closer look at my serial port options.
    Mar 2004
    atlanta
    34
    Neat thing bosch ecu's do is for all ram/rom writes they double store the info, and use two's complement on every read/write and fault the ecu if anything goes wrong. Very smart.
    So you guys at hptuners figure out how to have a high/low switch chip yet? Interface an unused input to dynamically switch say timing and fueling maps?
    then we could have like two payloads on one chip. Would make tuning twice as fast or say a 100 octane/93 octane mode or for boost heads/etc more flexibility.
    ie nitrous map that retards timing on the fly when the arm switch is hit.
    That would rock. You could do something really fancy like multiple modes including security (no start), valet (reduce power mode ala wife mode), high octane, low octane).
    That would kick the piss out of the other products. Tuning is one thing but if you can add more features that would rock.
    the bosch cars use the cruise stalk, and then the SES light blinks at a rate to show the user what mode they are in.
    I'd buy that for a dollah
    Nov 2002
    Central Florida
    2,503
    I've tried to dig up a means of triggering the Normal /
    Performance mode select, so far all indications are
    that it is a serial data command from the BCM. GM
    might have hidden some kind of "secret dance step"
    in the F-body BCM/PCM combo but I have yet to find
    any good info, and not for lack of looking.
    But maybe some code-disassemblin' guys can run it
    down... all those Performance tables going to waste,
    is a shame....
    Mar 2004
    atlanta
    34
    how well does the scanner fair with key off/key on's.
    like if i want to log and im staging and accidently (oops) stall the car, i don't want to hold up the line when i restart. same with cold/warm start logging. There will be alot of work to get it from stalling and alot of restarts.
    does the logger behave well with key off/key on restarts?
    that was my biggest peave with efilive scanner.
    Sep 2002
    Chicago, IL
    6,395
    Scanner will not re-start if it loses communications, its an issue we will fix in the future versions.
