Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
Thread: HP Tuners - Can you do this!!
  1. #41
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Chris@HPTuners View Post
    ok i added this to VCM Controls, General in the scanner. "Throttle Cleaned Reset".
    2.23.509 or later
    Chris...
    Freaking awesome update Chris! Only problem is my cold starts went to shit.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
  2. #42
    Jun 2008
    Charleston, SC
    969
    2.23.509 or later
    Chris...
    Chris,
    Nice work! Throttle clean, trans clean, fast learn. Any other special features/procedures available?
    -Carl
  3. #43
    Jan 2010
    16
    i just get to this thread because i had this problem today with a 08 truck, this is not the first time it happens to me, it hapened everytime i clean a trhottle body on GEN IV, and dealer allways fixed the problem, now i glad i can do it with hptuner and i can't wait to try it.
    thanks chris!!!
  4. #44
    Jan 2010
    16
    where is this idle relearn on the Snap On scaner??
    Quote Originally Posted by flame View Post
    There is a procedure for this and Snap On has it available on their scanner to do it in about a minute. I had a 2009 1500 5.3L that I cleaned a throttle body on and it idle fine right after backed it out of the shop fine. Road tested and pulled back into the lot put it in park and the idle was 2000 rpm didn't matter what I did with the pedal. Eventually it threw a code for idle speed to high. I grabbed the scanner and performed the idle air relearn and bingo problem solved. The pic is for a 2007 Vette. You could try leaving the battery disconnected overnight and see if it will clear what is learned.
    i had been dealing with this problem about 3 years ago in my shop, since i did my very first trhottle service on a GEN IV and i allways had to take them to the dealer to do a idle relearn. i got the VERUS from Snap On bundle 9.2 and never had seen this idle relearn function on it. could you let me know where is it?
    thanks in advance.
  5. #45
    Apr 2009
    613
    On the Modis 11.2 under function tests -> module setup -> idle learn reset
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
  6. #46
    Jan 2010
    16
    thanks flame, i guess a have to update to 11.4.
  7. #47
    Feb 2010
    400
    Were can I get this latest update?
  8. #48
    Apr 2009
    613
    email support
  9. #49
    Mar 2007
    5
    HLOOO
    PLEASE I NEED HELP FOR SIEERA OR SELVERADO 2500HD _3500HD 2012
    I NEED SPEED CUT AND ADGUST TUNER
    THE VCM HP TUNER NO READE FAIL THES TRUK
    I NEED READE AM NO 23 TRUCK FOR THES PLEASE HELP
    [email protected]
  10. #50
    Feb 2010
    400
    Quote Originally Posted by kingtuner View Post
    HLOOO
    [email protected]
    This isn't the spot to post this! You may need a definition file created. You can email support, or post else were in the forum, like Gen IV engine, or Hp tuner general
  11. #51
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    HLOOO
    [email protected]
    i couldnt understand u
    email [email protected]
    with ur hp number
    they will send u a newer virsion
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
  12. #52
    Sep 2007
    5
    there is a learning function to correct the throttle as it becomes dirty. I will add the learning reset function to the scanner.
    Very nice! Appreciate the customer support.
  13. #53
    I've tried this relearn on 07 escalade without any success...engine off, key on...
    Am I missing something??
  14. #54
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Quote Originally Posted by BMBSALES View Post
    yeah first time i tried it on a 2008 HD it worked like a dream... then it just decided to stop working..
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
  15. #55
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Trying to do this on my 2006 TBSS (E40). It's greyed out with KOEO and KOER. Is there a special trick to this?
    http://www.dsxtuning.com
    Just say no to bull s***.
  16. #56
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    No workey on the E40. It was set up for later ECM E38 and so on.
  17. #57
    Feb 2010
    400
    Getting P2176 with a E40 from a 06 Grand Prix, love to do a idle relearn. How can we get the learn function added for the E40? Please!
  18. #58
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    you can try this works for me most of the time turn key on engine off, let stay on for about 3 minutes, then back off. then key on engine off again about three minutes, then back off, let key stay off about 3 minutes, then restart. usually works. But there has to be no codes. so you have to perform a code clear first. the three minutes allows internal pcm timers to time out, and allow itself to perform self checks, and ironically with gm idle is learned with engine off, not on.
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
