I have a new setup that I am trying to get running right
motor:
ls2/l92
223/231 .610/.617 113LSA +4
ls3 intake
4 inch intake
1 3/4 headers, full exhaust
60 lb injectors
return style fuel setup with vacuum line to intake manifoldK
with a t56 transmission and ls1 pcm (gto)
I just got it to idle HALFWAY decent but i feel like it could be much better if the timing wasn't jumping all over the place. (IAC ~50 at 230 degrees with fans turned off)
I followed the ls1 tuning guide instructions and have the car in open loop. I haven't adjusted the fuel yet so that too may be an issue.
I don't know what the ethanol content is exactly so I set stoich to 14.4
I'm planning of tuning the VE table first then the maf.
I'm not sure which order to attack this thing from first.
Idle AFR
Idle timing
RAF
Any guidance would be greatly appreciated. I've attached a copy of my tune,the config i'm using, and an idle log. I'm new to tuning so if you see I've made a bonehead mistake somewhere please feel free to point it out
