Is the value listed in the idle overspeed/underspeed table the max that the PCM can use or the value that it will use?
For example, if I have 5* advance in the underspeed for -300 rpm, will the PCM automatically command a 5* increase in spark if a 300 rpm deficit is seen, or will it just have the authority to use up to 5* to correct it?
I figure it makes a big difference one versus the other. With one, you might want to keep the number lower so the spark doesn't vary as much. With the other, you might want to make the number bigger so it gives the PCM more leeway in choosing the correct value.
