So, I'm trying to determine what has happened here. The truck starts and idles normally, drives fine, but when at the hit for WOT the AFR drops to 10.9 and then she start popping, stumbling, and crapping, then pulls hard, then craps out again and well is a total mess with the AFR going all over the place, but fuel pressure and Injector Duty Cycle is staying constant. I had it tuned perfectly the other day. The only things that's changed is 13 gallons of fresh 91 got poured in last night.
I didn't find anything out of place on the log. It's not knocking either. The only thing that I know can be to blame is the fuel.
The log attached, you can see where it's running good, then it starts crapping out by the O2's going nuts. Let me know what y'all think. The best example is at frame 6950.
