Can you make a back up copy of your PCM image?
If you happen to make a big mistake can you restore the original image?
Or say you put the car back to stock and you want to put the stock programming back in, is this possible?
yes, although entire PCM reflash is not required for that STD version is all that is required.Originally Posted by smokemup
I count sheep in hex...
I don't understand. I'll assume you said it can be done but not on the standard version of the software.Originally Posted by gameover
Is it only supported on the pro version?
Please explain.
sorry bout that.
To restore your stock calibration you do not require the PRO version, STD is fine
