Results 1 to 6 of 6
Thread: Slight off idle bog
    May 2008
    Texas
    119
    Slight off idle bog
    Background:
    1999 4.3 S10
    Marine MPFI intake
    MotoTron 60# injectors
    SyTy manifolds/turbo, etc
    Symptoms:
    Under medium (and probably heavy) throttle load immediately off idle,
    there's a bog before the RPMs kick in and then everything runs great.
    How do I troubleshoot? What variables should I monitor or tweak?
    Thanks!
    Feb 2006
    Canada
    1,957
    Post the log and current tune bud, it'll get figured out. Just get a log with the built in config for now. Once we see a scan we can figure out what else is needed to try and help
    2000 Trans Am WS6
    May 2008
    Texas
    119
    Quote Originally Posted by MMGT1 View Post
    I probably can't get it done until next week, but I will do that. Thanks!
    May 2008
    Texas
    119
    Ok, I finally got around to grabbing some quick logs.
    My latest tune and a few logs from today attached.
    I certainly don't know what I'm doing, but looking at
    it my GUESS is something to do with the timing being
    pulled so much immediately upon hitting the throttle?
    If that's an issue, is it related to "Burst Knock Retard"?
    Just tossing around ideas?
    Dec 2007
    16
    I would assume once your MAFand VE ( if you want to) is tuned you need to start tuning AE and DE. There is a thread not to far from this one that has a link for a "how to tune AE and DE". It will help with that bog your talking about. I have not done this but the OP of the thread found out that tuning AE and DE helped with bogging.
    -Patrick
    2000 camaro: zzp xp-cam(130vs,dual timing chain,retainers),Hp tuners pro, LM1 wideband, pacesetter headers, custom true dual exhaust, full intake, stock lsd and 3.42 gears, !egr, msd wires, blistein rear and KYB front shocks.
    Build in progress: Procharger P1sc-1 head unit, headunit rebuild kit, bosch by-pass valve, Walbro, progressive AEM meth injection, custom bracket, no intercooler.
    PB 1/8th: only mod was Flowmaster muffler 9.94sec
    May 2008
    Texas
    119
    Quote Originally Posted by Gotchocmilk39 View Post
    My truck doesn't have any AE and DE tables. Seriously.
